onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Feb 21, 2006 6:45 pm
Well, I believe all you would have to do is change out the rear cover. You may also want to check the 2 bolts that mount toward the front of the diff, there's issues w/ j30 stuff etc, don't know if that applies to the s13->s14 debaucal.
Lastly, you would only need to check the length (i.e. s14 may have abs which makes it longer, putting in a shorter diff may be a problem).
s14 -> j30 diff direct bolt-ons13 -> j30 diff - swap rear cover
soooo
s14 -> s13 - swap rear cover, verify bolts for front (should be same but I'm not 100% sure), and check length.
