Edub1 wrote:I haven't used one but most say the T3/T04E has little lag. A super 60 is instant from what I understand.
T3/T04E's are pretty good as far as minimal lag is concerned.
Edub1 wrote:The T04b is a different compressor. I think I made a post called "choosing a turbo" or something that explains how to read compressor maps. I hear the b is an older unit that is less efficient.
This is true...I just looked at some plots I have done in the past, and when the stock KA24DE is concerned (ie stock cams, no substantial head work, compression close to stock, no juice, etc.) the T04B is a very poor choice. Depending on what the target boost is, you would most likely be off the map completely at certain RPM points (often in surge) and for the RPM points where you are on the map, you are in the lowest effeciency islands.
If you can provide some specific turbo specs that you are considering, I can compile some plots and post them.
As far as what to do on an 8 PSI setup, you can get away with running an SAFC and maybe retarding timing just a tad at idle. That way you will already have some timing pulled when the car is boosting at PSI. Not optimal, but safe. Definitely need to figure out what you're going to do for fuel delivery here though.
On the Enthalpy topic, if you have not done business with him in the past, ie you don't currently have an ECU and tune in your ride, it might be tough to get one. From some posts I have seen over on FA, it seems Scott has taken a full time job, which he is devoting a great deal of his time towards. During his off hours, he is prioritizing his time to fullfilling orders he had prior to taking the job and to helping retune those people who have already payed him money. I have been trying to contact him for over two weeks now and no response. Supposedly he is anwsering in the order in which he receives e-mails...
So if you can wait a long time, the Enthalpy ECU is best for your situation. If you can't, I'd look into getting a JWT ECU and fine tune with an SAFC. Or if you want to learn to tune yourself, I'd consider a BikiROM or PLMS type of setup...however this will require you to devote a great deal of time to learn...and learn...and learn some more...and might take more time and money than you are ready to devote to. Just have to figure out what your goal is and take steps towards reaching it.
