will an auto s13 speed sensor fit an s13 5spd
240driftguy
Car: 91 240 sx
[youtube][/youtube]
I don't have a speed sensor for my 5spd so can I use the auto one, the way the bolt hole is is a little different but it slides in. will it work ?
biggie
It should fit, but won't read the correct speed.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
No. The auto Speed sensor will not directly bolt in. The auto one IIRC was bigger than the Manual Speed sensor. Also I thnk if you are using a SOHC trans in a DOHC car you should swap speed sensors.
breadbox
89 Koop
84 720 4x4KC
Just look tbhrought the part outs and drivetrain classified. you should be able to get one within the week pretty cheap.
