Will an Acura Integra wheels fit my S13?
GuSpeed
I have a set of Acura Integra wheels with new tires and wanted to know if they will fit on my 1990 Nissan 240sx.
180fan
Car: 89 fastback
no, they're 4x100. you need 4x 114.3
GuSpeed
On my 240sx, the front has a lot of tread and the back has some tread should I swap the fronts to the back? Then replace them all when all are almost gone?
s14a
Car: 98 240 white
y.....y god y
180fan
Car: 89 fastback
if you're talking about taking the tires off the integra's wheels and putting them on the 240, then sure. But, that's only if they're the same size. Your stock alloys will take a 195/60/15 or a 205/60/15.
GuSpeed
no i was talking about taking the front wheels of my S13 and put it in the rear and the rear to the front since I have more tire tread on the front. Will a 205/55or50/15 fit on the stock S13 wheels? Whats better 195/60/15? WOuld it be cheaper?
HolyShiznit
Car: Working on my car
To quote something from my childhood.......
"Good grief Charlie Brown......"
APEXi240
Car: 08 Nissan Versa S hatch
GuSpeed wrote:no i was talking about taking the front wheels of my S13 and put it in the rear and the rear to the front since I have more tire tread on the front. Will a 205/55or50/15 fit on the stock S13 wheels? Whats better 195/60/15? WOuld it be cheaper?
Yeah, that is called tire rotation. For some reason people tend to do it every 7-10k.
WTF:confused:
zombieman
he or she is probably asking that question because of the fact that the 240sx is a RWD... and probably thinking if a car is RWD, it's better to have traction on the rear than the front.
why would you want to put integra rim on? Chances are, somebody might take a picture of your car and posted on the net of a "car with a mistaken identity", just like how we spot people having VTEC signs on car that's not a honda.
GuSpeed
reason why i wanted to put the integra rims is that it has some really nice racing tires on it brand new. The rims don't have the logo in the middle to show that it's an Acura.
SmithSR
Car: 240sx
205/50 or /55 - 15 will work fine on your stock rims, but the other issue you're talking about.... the Acura wheels won't fit on your car. Unless they are ITR wheels, which happen to have the 5x4.5(114.3), and that would mean you need the 5 lug hubs.
The Nissan hub bore is 66.06mmThe Acrua Integra Type R hub bore is 70.30mm
The hub bore on the Acura wheel is larger, meaning it will fit over the smaller Nissan hub.
So, the only Acura Integra wheels that will fit are the Integra Type R units, and that would only happen if you had the Nissan 5 lug hubs on your car.
Again, your car(if 4 lug) has a bolt pattern of 4-4.5(114.3mm), and the standard Integra wheels have a bolt pattern of 4.100mm, while the ITR wheels are a 5-4.5(114.3mm). Clear as mud?
SmithSR
Car: 240sx
P.S. this should be in the Tire/Wheel forum
PHIL:)
