Tx-Sx-FS »
https://forums.nicoclub.com/tx-sx-fs-u14620.html
Wed Jun 02, 2004 12:25 pm
well i bought a 95-98 dohc intake for my 89 sohc...the only problem i had with it fitting was the pipe bend right infront of the intake manifold and throttle body..the dohc bends down and the sohc im guess comes straight out...so there is that bend that is an issue..but i just put mine in the correct spot and tighten the clamps..fit fine...all of the other parts like MAF and vacuum lines hooked right up in same spot...so it will fit
