So i drive an 01 maxima and the hub and bearing are completley effed on my passenger side. I drove on it till i couldnt anymore since it was my daily and i needed to get from point a to point b. It finally hit me that i could get this from a junkyard for cheap. Ive been to 2, and all ive seen was A32s.
I was wondering if i could use the front hub and bearing from an a32 to replace the one on my A33 and fix the problem for cheap. Only reason i dont think its the same is because to get the bolt off the front hub for an A33 you need a 32mm socket. On the A32 the 32mm is too small so its either a 34 or a 36mm
