will a verticle door set up for a 240z fit an 82 280zx?
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
280ZXsteven
Car: 1982 280zx n/a
i found a set on thezstore.comi realy wanna do something different with my car to make it unique. the price for it is 1g and i found a full body kit set up for 780$ and a spoiler for 250$ i have about a 3000$ budget and i wanna put every penny into the car.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
nope, looks like they don't make a kit for the s130, I'd suspect you'd have better luck modifting a kit for a Z31 as they are more similar mechanically and actually had wiring in the door
that being said I think lambo doors are ricetastic and the money would be better spent makgin the car faster or handle better, these doors kits are quite heavy and will only slow your car down
280ZXsteven
Car: 1982 280zx n/a
yeah true true. would a cool air intake and performance headers with straight pipes make a noticable difference?
evildky
06 Nissan 350Z GT
the stock intake is cold air, it's in front of the radiator, the stock injection system is the real hold back, and it a header, as in singular (it's only one unless you get the dual setup from MSA, most others are singular), cone air filter, header and mandrel bent exhaust with low restricion muffler might make a 10+15 hp difference, on such a low hp car it would be noticable especially in the et, I'd recomend agianst straight pipe on an n/a
280ZXsteven
Car: 1982 280zx n/a
thanksis there a "super chip" that will work on a n/a zx?
evildky
06 Nissan 350Z GT
I don't think there is any chip for the stock ecu, you can convert to VG30E elecronic's and injectors, there are quite a few using the vg30et electronics ont he L28ET, althouh with an N/A L6 it's more popular to comvert to carbs and run tripple webbers
280ZXsteven
Car: 1982 280zx n/a
how hard would it be to throw a RB engine in? I was looking at them on ebay and there not too expensive. I think the most I saw was like 2000 including shipping charges. comes with the trans/shifter, engine harness,turbo,a/c and many more parts. 35000 miles on it. that's the basic set up for all of them I saw. how much fab work would have to be done to put one in? I have a 3000$ budget right now
evildky
06 Nissan 350Z GT
you're looking at the RB20DET, not worth it IMHO, you loose almost a third of your displacment, you could swap an L28ET for less and make as much power, that being said the S130 crossmsmber might be an issue, when installing any RB into an S30 the RB20 oil pan si required, but the S130 crossmsmber sits forther forward and is wider so I have no idea if it would even fit, also the steering linkage could be an issue, if you want power on a budgert find a wrecked 82-83 280ZXTurbo, and just swap engine harness and ecu over, direct bolt in and plenty of power potential
280ZXsteven
Car: 1982 280zx n/a
sounds reasonable. but with a n/a engine, there isnt much i can do to it. how much would you say a turbo engine would run for?i wanna get the hp up as much as 3g will take me
Modified by 280ZXsteven at 1:56 PM 2/29/2008
Titus_RacerX
Car: 1973 Datsun 240Z HLS301-152443
Why don't you just put a small block chevy in it and be done with all the questions that stray from the thread. Lambo doorz... pleez. After that I suppose you want a 4 foot wing off the back and tires that stick out 5" past the body.
280ZXsteven
Car: 1982 280zx n/a
hey i just wanna do something different you know? i mean how often do you see a old z car with verticle doors? if the off topic title of the thread realy bothers you then you dont have to read it
Return to “Datsun Z Forum”
