Will a QX4 hid headlight fit in a Nissan Pathfinder?
zimm1344
Car: 2003 Nissan Pathfinder 4WD
I want to put the QX4 headlight unit into my Pathfinder with little to no modification. Also, anyone know of any site to find really cheap Brush guards, bumper guards, and tail light guards? I would really perfer not paying $500 for some steel tubes. Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
just by looking at the pictures, the QX and pathfinder headlights are significantly different, i dont think it will work....
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
I'm sure it would work if you were willing to replace your hood, grille, and anything else that I may be missing.
Also, on the later model Pathfinder, aren't the turn signals in the corner lamp? The QX4 had seperate signals in the front. This means that you'd lose that with the HID (2001+) equipped QX4s, since the corner lamps and the headlights are one piece.
bml94gxe
Car: 03 Pathfinder 3.5
yea you would have to replace stuff, the gaps between the bottom of the light and the bumper are different, plus a pathfinder is a flat bottom light, qx4 has a curve to it. the turn signal is in the fog light in a qx4 also
