GreenQ45a »
https://forums.nicoclub.com/greenq45a-u15134.html
Wed Apr 21, 2004 4:10 pm
My Q stands tall normal hight (same as my 93 q45)Actsus Light is on and she won't run the Self-Diag.I tried running the test Soooo many times.
Have the proper amount of A- fluid in res.
just finished:
cleaning engine bay, replacing valve covers, cleaning Throttle body, new Plugs, belts, tracked down and fixed several p\s leaks, cut roters, new pads, bleed brake system.
now its time to worry about the active system.that is the reason I wanted this car.
I DON'T want to convert this car!!! So dont even ask.I think you should trade a non-active Q owner your car before cutting and mutalating such a great car.
I understand the accumelators go flat and I'm going to replace them soon.
before I do I want to make sure the rest of the system it not leaking and no other problems exist.
Can you bleed a Q's active system without a consult?
