Depends on how hard it is for you to buy and tune a standalone.Dustin240 wrote:How hard is it to just use a map sensor and forget the mafs?
I'm trying to let go of an N60, good condition with an 8 inch harness.Dustin240 wrote:I need a mafs that can handle 13 or 15psi -300,350whp-. The z32 mafs are to much $$$. I'm runing a e-manage blue so u know.
I would suggest using the hot-wire setup. It can be tuned with an old SAFC from Apex'i, it just adjusts the voltage output to the ECU. It will of course require some tuning to work perfectly with your car, but we're talking about increasing the area of your MAF sensor considerably.Dustin240 wrote:How hard is it to just use a map sensor and forget the mafs?
