Will a KA24DE fit in a nissan Truck?
sil80dreamer
Im pulling the KA24DE out of my s13, and mu uncle has a 1986.5 Nissan D21. He was wondering if my KA would work in his truck. Anybody know?
slydin'240
Car: 1993 240sx Coupe, 2003 Maxima SE
I don't see why it wouldn't, afterall the KA is a truck motor.
i need tires
Car: 91 s13 coupe... coming soon
with the right amount of money anything will work
but yes do it!
ghettoslide
Car: '90 240sx, '91 240sx, '98 DSM, '05 Avalance
I believe the KA was used in the hard body. I have the slave cylinder from one on my 90 240. Another thing i had to replace fast. This car has given me hell. If you look at a hard body the engine is identical. I'll bet tuned different, but esentually the same
240crawler
Car: 1991 240sx
You have stolen my idea. I have a perfectly good stock s13 de. I wanted to put it, the transmission, and the entire rear suspension in the truck. Yes, I said it. I want to build a truck that handles. Grip driving is starting to really catch on here, after drag racing has gotten old and all the Hondas have been wrecked from e-brake drifts at Wal-Mart. I want to lower the truck to help the CoG, and use my Tokico and Tein package from my DD. I think with a little work, I could have a fun, reliable truck to play and maybe win a little money.
BIGT94z
240crawler wrote:You have stolen my idea. I have a perfectly good stock s13 de. I wanted to put it, the transmission, and the entire rear suspension in the truck. Yes, I said it. I want to build a truck that handles. Grip driving is starting to really catch on here, after drag racing has gotten old and all the Hondas have been wrecked from e-brake drifts at Wal-Mart. I want to lower the truck to help the CoG, and use my Tokico and Tein package from my DD. I think with a little work, I could have a fun, reliable truck to play and maybe win a little money.
juat wondering....what kinda truck u gonna do that in (nissan)
240crawler
Car: 1991 240sx
I was thinking about an early 90's hardbody. I have never really looked under one, but with a welder and a little time, you can do anything. I had a 91 Toyota pickup once; I tried everything to keep the rear in check through the turns. I simply could not keep it stable. I have also considered buying a very old Datsun truck, simply because retro is cool. Imagine if you will a fully independent Datsun with a 175hp KA. There would be chaos in the sport truck community. Most of the sport trucks here are Chevrolets; a mix of full size and the S-10. There are a few V8 Dakotas, but they primarily focus on the 1/8. I want a truck that will keep up with my s13 on a curvy road. Within 15 miles of my house, there are over 20 roads at least 5 miles in length with no straight shots. Grip driving has literally exploded.
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
uhh, i dont really think trying 2 grip with a truck is a good idea, the weight ratio of trucks will probably give really bad oversteer, IMO
figment521
Car: 89 240sx
yes it will fit, but there are problems to work around. the S13/S14 have a front slump oil pan. and the D21 has a rear slump pan. the locaton of the dizzy and well as the oil pump is differant. the pullys are all differant as well. and then you have to work on the ecm and wireing. if the truck had a nap-z engine( low pressure tbi system ) than you will need a fuel pump and tank for a ka truck. All of this can be worked around given a little time and money.
S3t0_S13
why would u go through soo much hassle in the 1st palce?
figment521
Car: 89 240sx
For the same reason that S13 owner change to a sr20, or a ka24de or a ka24e-t; to get more power, or they have one so why not, and so on.
sil80dreamer if you what to do this go look for so info. in the mini-truck scene.
acrazyjohnny
if u look in the newer frontiers they have the de. put s13 cams in them and call it a day.id take the 5th gear out of an s13 transmission and put it in the truck so u can go above 90mph lol
FliMSiCaL
Car: 1989 240sx 1994 sentra limited edition
if you take the engine out of a 240 and put it into a truck, i am almost positive the transmission has to go with it. I found this out when i was going to put a truck ka24e into my 240, it doesn't even come close to mating with the s13 transmission. Every bolthole is different. I am pretty sure the reverse (what you are doing) will be the same.
figment521
Car: 89 240sx
I put a truck block in a 240 there is no fitment problem other that what has been list above.
wynnEZ
Car: 90 240 CA POWA!
The ka24de is a truck motor. Thats why everyone hates them. But i love them b/c the sr's are so common.
