Will a JWT tuned ECU from a 95' work with my 97'? and the same specs
240dx
Car: '97 Nissan 240SX LE
I can get my hands on a freshly JWT tuned ecu out of a 1995 240sx for fairly cheap. Would it work on my 1997? All the specifications are the same (ie, turbo, injectors, exhaust ect...) Anybody think this may or may not work?
Thanks
and yes, I searched
Kraelic
Car: 89 240sx
1995 was still OBD 1 and 96 97 and 98 were OBD 2, most likely you will need a tuned OBD 2 ecu.
Darchangl
Car: 95 240sx Ka-t (in progress)
That is inccorrect. they were obd1 in 95 but still had the obd2 ecu. obd 1 ecus had a white connector and the obd2 had a blue one.. or the other way around lol.. dont remember at this moment .Talk to ben from jim wolf. he will answer you questions but i wondered the same and he verified. I am using a 96 obd2 ecu in my 95 and no problems. However let it be said that the wiring is a lil diff but nothing you cant remedy with a little soldering and a wiring diagram. Its basic stuff not even needed unless its your daily (ac etc.).
480sx
Car: 1996 Pearl White 240sx
You should be good, the s14 harnesses were ALMOST all OBD2 compliant harnesses. Should be plug and play.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
Did they make a running change halfway through the 95 model year? Because my 95 does NOT have a standard OBD2 connector, it has the old style Nissan Consult connector like an OBD1 Nissan would have, although it does have dual O2 sensors and a few other OBD2-ish bits, which is why I ask I suppose.
KFL
Car: S14
Off memory you can, just have to switch 3 or 4wires off the main harness. And you have to run a 95 02 sensor I believe..check Jim wolf's technology website they should have the info about 95ecu into 96-98.
480sx
I use a 95 OBD1 harness in my s14. Its got the single wire O2 sensor, ect. Iv used both OBD2 s14 ECU's and S13 ecu's with a conversion harness.
KFL
Car: S14
"MODIFICATION TO 97+240SX (S14) ECU HARNESSTO RUN A ‘95 OR ‘96 240SX ECUThe following three wires must be relocated as shown below to allow a 1995/6 ECU to run correctlyin a ‘97-’98 240SXThe rear O2 sensor must be changed to a EARLY 3 WIRE type sensoror the MIL light will come on. Transfer the plastic electrical plugfrom the original 4 WIRE sensor to the new EARLY 3 WIRE sensorusing the diagram numbers.· EARLY 3 WIRE sensor wire # 1 inserts in 4 WIRE plug hole #1· EARLY 3 WIRE sensor wire # 2 inserts in 4 WIRE plug hole #2· EARLY 3 WIRE sensor wire # 3 inserts in 4 WIRE plug hole #4· 3 WIRE sensor does not need the additional ground wire sothe 4 WIRE O2 connecter hole #3 is no longer used.· An 18 m.m. to 12 m.m. bushing or adapter must be made tophysically install the earlier 12 m.m. sensor"
Electrical Wiring http://www.jimwolftechnology.com/tech_details.asp
