Will A Dual Overhead Cam fit....
Jlights420
Car: 1990 Nissan 240sx
my single cam for my 240??
pr240sx
nope
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Are you asking if a DOHC KA (91-98) with fit in a SOHC (89-90) 240???IF you are the answer is YES...
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
9240sx wrote:Are you asking if a DOHC KA (91-98) with fit in a SOHC (89-90) 240???IF you are the answer is YES...
Dude you are a jerk leave the idiot that asked the question alone.
Ezzo
No it will not, Don't listen to him. The reason why is because the SOHC cam has the intake and exhaust lobes on one cam wile the DOHC splits the lobes into one exhaust cam and one intake cam.
Ajax
Car: 1991 240sx SE
2010 Mazda 5
Wow. back up the hostility train.I think 9240sx assumed the question was asking if the DOHC engine will fit in a 89-90 s13, which it will.But if the question is asking if a camshaft from a DOHC will fit in a SOHC engine, then the answer is no.Hope this helps.
S13 240SX
Car: 93 Mazda Miata
alright enough with the gay jokes... thread starater... just swap a dohc cylinder head to your sohc ka block.. there ya go then your have dohc ka camsafts.
Red coupe
Car: 92 Nissan 240sx Coupe
S13 240SX wrote:alright enough with the gay jokes... thread starater... just swap a dohc cylinder head to your sohc ka block.. there ya go then your have dohc ka camsafts.
Have you done this?It seems to be quite a more then "just swap a dohc cylinder head to your sohc ka block"there were several people trying to make this work for a while, and I never saw one person compleate it....
S13 240SX
Car: 93 Mazda Miata
Red coupe.. i'm sure it'll work even though people never compleate it.. i'm sure the reason why no one ever compleate was probably becasue they all firgued it was a waste of time. HEH
Red coupe
S13 240SX wrote:Red coupe.. i'm sure it'll work even though people never compleate it.. i'm sure the reason why no one ever compleate was probably becasue they all firgued it was a waste of time. HEH
Well there is the issue of fitting the timing chain cover, but that seemed easily overcome with some welding.
I dunno what the other issues where but there were at least 3 people I saw working hard on getting it done...there were a few threads more then 5 pages long on people troubleshooting it to get it working...It doesn't seem like it would be hard but apparently it doesn't just fall together...
And yeah, cause 11:1 compression is a waste of time
Ajax
Car: 1991 240sx SE
2010 Mazda 5
I believe there was a completed example of the DOHC head on a SOHC block. Probably about a year or two ago, though, so good luck searching. But I think its easier to swap SOHC pistons into DOHC engine than to swap heads. I wouldn't know for sure though, I've never tried either.
