deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Jan 18, 2005 6:03 am
The 240sx ka crankshaft is at least 1/4" shorter overall than a ka truck/z22/z24 or any other z or L. The difference in length is in the rear main seal/flywheel mounting portion of the crank. The offset of the flywheels is different, if you use the non 240sx flywheels on 240sx block and crank the ring gear/starter will be that much off (will most likely work, obviously, although premature wear on those components? possibly). Also the throwout bearing distance may be off depending on which pressure plate/throwout bearing you use, as there is a few options. White Bunny over on FA did this swap long ago and posted up his findings, he used a 1/4" spacer + ka/z24 240mm flywheel (truck).
Now a ka truck crank would go into a 240 block although ring gear/starter distances become and issue, and the starter mounting setup on the 240 block is difficult to modify and/or swap different starter motors.
Im not saying it wont operate with just the straight swap, yours obviously does. You may want to inspect your starter and ring gear next time you have a chance for any odd wear.
