lolsebazztard wrote:but i would rather spend the money on beer for a month.
A short ram intake I'm guessing puts the pipe and cone filter or whatever it comes with, on the same side as the intake itself. should include a significantly shorter tube and the filter can be put where the battery sits. (which would obviously require a battery relocation to the trunk)This would help get more cold air to the intake. but is it really needed?hazukijitsu wrote:So does the same go for a short ram intake? Whats the difference?
IF it's a true CAI that goes under the fender and picks up air from under the car then it MAY produce some sort of value, although WAI (the ones that just replace the stock air box with a cone filter) provide nothing. A Short RAM on the other hand, is cheaper, nicer and actually gets cool air if done right. Since already being on the COLD side of the car (intake). When installed the battery gets replaced to the trunk. Then the Battery tray gets cut out. You can now install a small metal C from lower front bumper up to old battery tray area. Now when driving you have a nice cold area that your intake is getting air from. This provides the Short RAM with the same abilities of the CAI.blacksrjdm wrote:A cold air intake probably wouldn't rob much HP, but the short rams that everyone get for these may rob a slight amount of HP because your really not pulling any cooler air.
FYI - Metal (Aluminum) dissipates hot air faster than plastic.....a lot faster. Especially when air is running through it. Even better when cold air is running through it.EfiniRX7 wrote:I would think the plastic oem intake would be better than a metal one. The metal would hold in heat more efficiently than the plastic, depending on the thickness of the plastic. I figure since K&N charge $300 for a stupid intake, I could buy a nice used turbo for that amount. I dont know about you but I would rather make steps in the KA-T direction than an intake.
Im retarded, I was not thinking aluminum at the time. Seeing as how every cold air intake is made from some kind aluminum you would be right.Space Monkey wrote:
