will a 96 240sx engine fit in a 91 240sx
konan83
will it fit without making any changes.thanks
Slappy
Car: 1993 240 sx coupe
They are both KA24DE motors. It will "fit".
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
It will fit but you'll need to use the following 91 parts:- intake manifold assembly- throttle valve assembly- exhaust manifold
JeromeS13
Car: 2008 Subaru Impreza STI
+distributor and a few others
Why do people continue to ask the same questions, over and over? Seriously. This forum would have 12 posts if people actually searched...
-Jerome
Florida240sx
Got to swap over parts from your 91.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
konan83 wrote:will it fit without making any changes.thanks
There are some subtle differences in all the ka years. Just make sure the motor your getting is complete (valve cover, front covers, etc). You "should" swap the intake manifolds (use the 91). Give everything a once over and change some of the gaskets too. They are all easier to do if the engine is out of the car.
This topic has been covered to death so I added a new poll choice...lol Have a super day.
Spectre_240sx
Car: 1990 240sx SE
Does anyone have any links or references that show what parts need to be taken from an older KA? I've got a KA24E right now and I'm looking at swapping a DE in. The problem with that is that all of the OBD1 engines have insane mileage on them. Being able to swap in a later engine would be quite a help.
I did a lot of searching on this and came up with nothing. That's not to say that the threads aren't there, but finding the correct search terms is very difficult.
chuck-d
Car: 93 s13
hahah and thanks im doing the same swap and had the same questions. i heard this was a good forum, so i made an account. sorry all to all you nicoclub veterans that are tired of hearing the same questions...
rx-007
yes it will work for the 100,000,000,000,000,000,000,000,000,000
time, lol.
Spectre_240sx
Car: 1990 240sx SE
With a post count of 7, you have no reason to talk like that.
Anyway, I'm seeing that the following need to be used from an OBD1 engine:
- intake manifold assembly- throttle valve assembly- exhaust manifold- distributor
Anything else? Sensors or anything?
