rsiwicki »
https://forums.nicoclub.com/rsiwicki-u13199.html
Tue Apr 20, 2004 3:29 pm
Wes....please understand that I am doing this test with my "JWT ECU" and not my "OEM ECU" so I should be shifting well within the redline, but I can't get the rpm needle into the redline zone. The shifts are still at 6,900rpms. I tested the JWT vs. OEM redline limit by reving the engine while in park past 6,900 rpms and the OEM does cut off the fuel at 6,900rpms while the JWT cuts off fuel at 7,200rpms and I also tried this by holding the transmission in 1st gear and pushing it beyond redline.
The JWT ECU is good. I only really feel the JWT above 3,500rpms and the engine sounds a little meaner (stronger). I really notice a difference near 6,900. I now see the need to get a JWT TCU to run up to 7,200rpms.
I will be doing some 1/4 runs tonight at the track with & without the JWT ECU to see how the 1/4 times are reduced.
I will be keeping my 95 TCU and sending it to JWT to get it reprogramed so it is not for sale. I will have a 93 OEM TCU and a JWT TCU to play with.
