boooo! wheres the fun in that? jk!LongBeachCoupe wrote:functional thread title ftw!
I would just like to know if it would work for our A/C's. And any year 350Z or even the 370Z. don't matter to me.blackteam02 wrote:ok-ok "I have no clue"
What would a 350z throttle body do?
What year 350z??
Oh dude the Turbo is more then fast enough. I'm pretty sure that the throttle body would bolt up to our VQ. The only part I'm not sure about is if the harness will plug and work correctly. I was sitting at my office and think what could be done to the engine or the altima. Please explain further about the phenolic spacer dude. I'm interested to know.dangeris wrote:What? the turbo isn't fast enough for you Ricky?
I would imagine it would work as long as the bolt holes line up. But what's the use of that? A throttle body controls the amount of air that flows into the motor. Replacing it, IMHO, will do nothing. However, with that said, putting a phenolic spacer def. would affect the way the air comes into the motor. It would act more like a tunnel ram...sorta...
Find any good info that would be useful?FGFCacoupe wrote:Thats a great question, and if it will work, a definately needed find. Ill do some research on that asap.
thanks for the info of the phenolic spacer. I've had my turbo for about more than a month and the driveability of it is great. I actually didn't get a reduction of MPG. I actually got an increase of MPG.dangeris wrote:BTW, How long have you had the turbo and what do you think about the drive-ability. Did you notice a reduction in MPG? And is the reduction due from you hammering it to get on the turbo or because of the bigger fuel injectors, normal driving is compromised.... Sorry for the thread jack
Okay... call me stupid... but the ECU doesn't know about it, so it is metering the same amount of fuel-to-air. Traveling a longer distance by the size of a relatively small spacer (a couple of inches at most?) is not necessarily going to be more efficient, but possibly less so. The spacer will add outer wall turbulence to the charge, since it can't meet the intake pipe or throttle body perfectly, so flow could actually be worse, and how will you now fit a performance intake since there will now be not enough room for it? (Intakes are a tight fit already!) Like I said... I may be stupid! But I don't get it.dangeris wrote:There's no mystery with the phenolic spacer. It's just what it is a spacer. Basically you're putting more material thus increasing the space the air has to travel.
First we have to find out if the throttle body from a 350Z would fit and be fully functional. Then there could be modifications to do something similar.skiski329 wrote:This may be a bit off topic but could we get the dual intake setup like the 350z has?
Im going to try and take one of my mans z and get my mechanic to see if it bolts up correctly. At least he will take a close look at it. Ill PM you and let you know exactly what happens as soon as possible.Mr.Coupe wrote:
Ricky C.
nice! I love when people take initiatives like that I'll be checking back on this threadFGFCacoupe wrote:
Thanks dude. And please also check to see it the wire harness hooks up correctly and turn the car ON and give it some gas, drive around and test the F'ER out to make sure there won't be any check engine lights.FGFCacoupe wrote:
The thread wasnt even moved a full 24 hours ago, dont exaggerate!skiski329 wrote:Are there any new updates? (took me 2 days to find this post again. I hate when they move the thread)
I love this car, and just like anything else that I love, I strive to bring its full potential out everyday, rather it be my car or another human being.mcheddadi wrote:
No problem man, im on it, and if it can bolt up, ill do all of those things and do a write up so that you can see the entire process, step for step. So this way if my mechani or I have t make any minor adjustments, you will know exactly what to do if you proceed to bolt one up. So hopefully it worksMr.Coupe wrote:
Ricky C.
Yeah,Alt.ImaCoupe wrote:Hey Ferg,
From my prev G Sedan, I know that intake spacers/plenums were popular on VQ engines a few years ago for a couple of reasons. The first was that the airflow to the front two cyclinders was compromised a bit due to a frame member on the 350 that required the engine to be a little shorter in height. The same plenum was used for the Gs, so companies (like Motordyne) started producing intake plenums with better flow to these cylinders with decent gains. There was also a spacer that fit between the top and bottom half of the stock plenum to achieve the same effect.
The thermal spacers were used, and made out of a plastic material, to help keep the air/fuel cooler and therfore more dense and more power. These sat below the plenum. They also increased low end torque a bit because a longer intake runner holds more air/fuel which has more inertia to keep it moving forward when the intake valve closes and the cyclinder isn't really sucking. The net effect is that pressure builds in the runner a bit and you get more air/fuel in the cylinder when the intake value does open. Once RPMs increase, you're exactly right, the added friction of the longer runner becomes a liability and you loose some top end power.
I don't think either of these situations apply on an Altima because our intake plenum is different and already made of a non-heat conducting material. Motordyne certainly doesn't make anything for the Altima, and they would be the obvious choice to produce it since they already have the parts.
