Will a 275/30/19 fit in the rear of the Q???
guadofreak
Car: 1994 Q45t
the rear rim looks is 19x9.5 and I plan on getting a 275/30/19 tire for it. Should it be ok??
I can't remember what the safe zone was.
the rim as a +38mm offset
I don't see why not.
I have 265/40/18's and there looks to be room to go 10mm wider.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
AZhitman wrote:I don't see why not.
Since when? I thought you were running 255/40-18 Asymmetricos?
Bought a set of wrecked 265's to "test fit", so my next "good" set will be that size.
Rex
Car: None
AZhitman wrote:Bought a set of wrecked 265's to "test fit", so my next "good" set will be that size.
AZ what's your offset on the 18's (both F & R), and what's your front set up again? Any Rolling up front?
Forged 18's are in the garage, they probably go on this weekend, if not sooner.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Rear only? Offset and wheel rim width specifications please.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I think with the 38mm offset you should be ok... 275-30-19=275-35-18=like 25.7 OD
I have 265-40-18s with 33mm offset (on 8.5) and it rubs a little even after rolling...
You guys KNOW what wheels I have...
18x8 '04 Premiums, no clue on the offset, no rolling or fender trimming.
