Will a 2003 G35's 17' stock rims fit a 2.5 Altima coupe?
LolMang
Sorry for the stupid question :\ I just don't know the details on the rims, my uncle has them stashed in his garage and said i could have them if i wanted :]
EOrdonez3229
Car: 2005 Altima 2.5S and 2006 SRT8 Jeep
Ask him for all the stats and refer to the top thread in this forum. You should be able to pull together your own answer with that.
For example, my rims:
18"x8"5x114.3 threading245/45/18+30mm offset
Good luck.
LolMang
He said he doesn't remember the statistics, but i looked at the G35 forum and it said this"1st GEN G35 Sedan OEM Wheel SpecsSport Model (2003-2004) & Non Sport ModelFront & Rear: 17x7 +45mm offset"So i'm guessing it should fit for the A/C?
EOrdonez3229
17x7 would def be no problem. It's the offset that I'd worry about. If he has them wrapped in tires already, I'd just go there and pop them on, see if you have any issues. +45mm offset may be an issue. I had an issue with mine being +30mm offset. But, then again, I drive an 05 sedan. I'd check around in the 1st Generation - Altima Coupe forum. You're more likely to get a definite answer there.
Good luck with them
LolMang
Thanks a lot for your help :] the offset for the altima coupe is +45.
EOrdonez3229
Yeah, I was thinking that with a 7" wide wheel, you'll be fine regardless of the offset.
I guess if that's the AC's offset, then you should be set my friend. I wish I had a hookup to free rims! That'd be a sweet deal!
Good luck man~
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
Look on the inside of the G35 rim - the offset is often stamped somewhere on the inside of the rim.
