zer0c123 »
https://forums.nicoclub.com/zer0c123-u10125.html
Tue Sep 07, 2004 7:15 pm
Not sure if your starter will work on a 93. Just resell it on ebay and get a good one from a nissan parts store or something...
The install is easy, but you really need 2 people to change the starter in my opinion. My friend helped me changed mine last July 4th, and i can't imagine how hard it would have been without his help.
Anyway the starter is near the oil filter and you have to get under the car to unscrew the 2 bolts. One bolt is easy to get to, but the 2nd one is hard to see, so you have to feel around for it. I pretty much had my friend uncrew the 2nd bolt from the top of the car, while i kept the wrench in position from under. I remember there is a nut that needs to be unscrewed from the starter too. (ground wire maybe..can;t remember) But you will see it once both bolts are unscrewed.
On my install the hardest part was unscrewing the bolts, since i was under the car, I had no leverage to turn the wrench. Also wear goggles or something to cover your face. Tons of dirt and crap fell on my face during the install.
