mbo37353 »
https://forums.nicoclub.com/mbo37353-u233590.html
Tue Mar 25, 2014 1:45 am
So I am going to be driving my 90 z32 na 133k auto to AZ from ND in may moving back. The car I haven't owned for long now maybe 2 months has been a little bit of a problem child but I've gotten it mostly cleared up since buying it. All the repairs/ maintenance done to in the past 2 months: Reman fuel injectors, new clamps on fuel lines + new hoses, New fuel pressure regulator, changed the oil + filter, New PTU, New spark plugs, new coil pack boots, new valve cover gaskets+ plenum gasket. Bypassed all the intake manifold coolant lines with new hoses. The car came complete with service records looks very well maintained here is a list of Repairs/ maintenance: Trans Rebuilt at 90k miles, had the spark plugs, Timing belt, and belts changed at 84K, the timing was advanced not sure around what mileage because of a vibration or hesitation for some reason by the Nissan dealership, new tires, and new battery about 2 months before I bought it. it runs a little rough at first start will stall with out the accelerator depressed but, runs perfect after it is fully warmed, Timing Maybe? also am going to get the tires balanced/ rotated and aligned before I go. Let me know what if you think this car will make the trip or if you think I will be stranded somewhere in WY UT CO or MT. also thing to check before I go Thanks! Also would love to hear about some similar long distance travels in your zs!
