Will 93 sentra radiator work efficiently on a s14
hakosuka86
Car: Toyotas Nissans
Hiits me kaoru I have a question my s14 didn't come with a radiator and I have a good condition radiator from a 93 Sentra its not as thick as the stock 240sx but i added 2 electric fans to it and I'm keeping the clutch fan.
would i have cooling problems???
thanx.
180fan
Car: 89 fastback
depends on what sized fans. I'd be more concerned about it fitting properly to the support than the cooling ability with the 2 electric fans. You'll probably be able to ditch the clutch fan if you're running electric.
hakosuka86
Yes they fit i went to buy sum tubeing t lowes and thres no leaks, Maybe i should take the clutch fan off, thank you for your comment.
neverlift
the clutch fan is gonne be more then you need with two efans, maybe one but two your cool
KRMOTORSPORTS
Car: 89 rb25det 240sx
The Radiator will work, i would make sure you fabricated some sort of air damn to force the most air possible through it, i have used various radiators that many guys have said would be to small, its all about airflow and heat transfer, your radiator should be fine
hakosuka86
Oh i was thinking of buying a cooling plate i seen sum for 50$$$thanx everyone i appreciate the help.see you around
