Will +40mm offset rims EVER fit 03-05 g35 Coupe?
AlpineReliant
Car: 2007 G35 Journey Silver
Are there any rims that exist that are +40mm offset that will fit a g35 coupe? or can sedans only fit rims with +40mm offset? and if you CAN fit 40mm offset onto g35 coupe how would u do it? any info would be helpful! thanks!
Bottom line, does +40mm offset fit g35 coupes?
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
I don't even know about the offset...
I do have a sedan tho!
Explain that to me and it will help me a lot!
DJ
AlpineReliant
Go Here:http://www.yokohamatire.com/utcustom.asp
and it has a useful explanation of offset and pictures to maybe make it clearer.
My only beef is that, I had a 17x7inch 6 spoke infiniti wheel from my friend, which im guessing is off of a 03-04 g35 sedan because the g35 coupes dont havem. i looked up the specs on it and it is +40mm. g35 coupe (which i own) is +30mm in front, +33mm in rear. I tried to install it and it did not sit flush on the hub. well i tightened the crap outta it, went and ran it and the nuts came loose! bad!!!!
so then i took it off, put my stock rim on it.
just no one wants to take a stab at my question, because no one wants to go smaller in the front, everyone wants wider. and plus i dont think anyone has ever done it before. just wondering.
i noticed the bolts don't go through the holes fully as they do on my stock rim. that's probably why the nuts came loose after driving.
Tampa G35 Sedan 6MT
thank for the web site... that helped be out a lot
I still don't even have an answer for you.
Maybe one of our Infiniti techs can answer that question for you
Sorry don't kow much about the two different rims DJ
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
If you run a 15-20mm spacer they will fit perfectly. You would also have to run longer wheel studs with that big of a spacer too.
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
Or better yet, just buy a 4th rim to match your others You may even be able to find one on this site. You'd be surprised what people have layin around in their garages
