Will 4.5" 4 lug wheels fit an s13?
naed240sx
Car: .....
15"x8", 4-bolt - 4.5", +1" offset. gold aluminum wheels 3-piece 4-lugs. I used them for 1981 Toyota Corolla, should fit on rear wheel drive Corolla 1980, 1982, 1983, 1984. w/ Pirelli P700 tires, 2 of the tires are almost new (2 are old/thin thread). 195-50VR-15. Won't fit on 2002 Corolla, 1994 Civic, 1998 Civic. It may fit Accord 1995 1996 1997. You can come by and check if they will fit on your car. "
^listing from add. So is a 4x4.5 the same thing as 4x114.3"? Math conversions say yes, but I want to make sure. Will these wheels bolt up? Offset will be fine, I am not worried about that, just need to know about the lug pattern. Thanks!
crzycav86
Car: 93 Nissan 240SX KAT
The bolt pattern is the same. Make sure the hub bore is the same size too(most aftermarket rims have large bores to accomidate various cars), but i'm just throwing out a warning. If you're not worried about the wheels sticking out, those wheels will fit.
srdrps13
Car: s13
crzycab what wheels are those on ur s13?
onosqv
Car: '92 240sx Vert
srdrps13 wrote:crzycab what wheels are those on ur s13?
look like kosei k1's...
And naed, yup, those rims will be gangsta gangsta! And yes, they will fit.
naed240sx
Car: .....
Yeah they are gonna be sweet. They will be drift spares, and I will be running some slightly stretched tires 205's. Because of the tire stretch, they should flush up nicely. They are made by weds.
SeVa-S13
Car: '05 GTO 6spd
Yeah watch it on the hub bore; Toyotas tend to use tiny bores, comparatively. But even then, a good wheel/machine shop can custom bore easily, I used to have it doen all the time at my old job.
naed240sx
Car: .....
SeVa-S13 wrote:Yeah watch it on the hub bore; Toyotas tend to use tiny bores, comparatively. But even then, a good wheel/machine shop can custom bore easily, I used to have it doen all the time at my old job.
how much to bore the hubs of 4 wheels? I am gonna mount them before buying, so it may not be neccesary, but it would be good to know.
SeVa-S13
Car: '05 GTO 6spd
I couldn't tell ya man, sorry. We had a running tab with the guy who was like a friend of a friend of someone or some crap...who knows. Plus it was in Hawaii so all bets are off. =\
naed240sx
Car: .....
Ok cool. Thanks for the help! Will be posting pics of the new wheel hotness if I end up getting them.
