will 31's fit with factory suspension???
Natedogg1701
Car: 2003 Nissan Pathfinder SE
I'm planning on putting 265/70/R16's on my 03 pathy, which translates into basically a 31x10.5x16. and i want to know if they'll woek with the factory suspension and ride hight, and wont rub on anything. I like to go wheelin and plan on lifting it in the spring, but for now i need tires and want to get the bigger ones now, so does anyone know if they'll rub when im off roadin or cause any problems?
fueler
Car: 2 Nissan's
2 BMW's
they should fit relatively easily with some trimming. I had even bigger, 265/75/16 on stock suspension but that was with a lot of trimming, removal of mud flaps, and bashing in metal parts with a sledgehammer.
But also remember this was with aftermarket wheels 1" wider than stock. Backspacing and offset will also affect where it rubs.
Short answer to your question - yes it can be done fairly easily with minor work.
Natedogg1701
i hope i wont have to do too much modification, and bashing in metal parts?! what did you have to bash in? lol
