will 300z rims fit on an s13
skylinetwo40
Car: s-14
will 300z rims fit on an s13 or is the offset to much? if they do rub is there some kind of spacer?
Flight_240
Car: 240sx, Integra DA
I thought 300z's are 5 lugs, unless u bought a five lug conversion on your s13.
SmithSR
Car: 240sx
To make the front fit, use 205/55-16(perfect OEM overall diameter) and plenty of really good tires available in that size.You can do 225/50-16 rear and still keep same exact overall diameter so no ill effect to gear ratio.
574-240sx
Car: Nissans, Toyotas, Subaru
I'm running a 215/50-16 all the way around. I had to add a 10mm spacer to clear the front coilovers. I getting 25mm bolt on spacers soon because there is about 2mm front the tire rubbing the coilover. I also need to lower the car about 1.5 inches more in front too.
