will 3.5 coupe mirrors fit a 2.5 sedan
Rkitkt
Car: 3.5 altima coupe
Hey guys done anyone know if the 3.5 mirrors, with the turn signals, will fit a 2.5 sedan? If so what would it take to wire the mirrors so the signals work? Finally, does anyone know the best place to by nissan parts on line?
Thanks to anyone who can help and sorry if this has already been posted but i could not find it.
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
They will fit.I don't know if the wires are already there or not though, and just as a personal choice. When I have to buy replacement OEM parts I use http://www.nissandiscountparts.com
Sorry if we're not allowed to link out to that website, I'm not sure
Franchise1124
Car: 2007 Nissan Altima 2.5S 6MT
Exactly. The fitment shoudln't be an issue as the mirrors are the same. Some 2.5s are actually pre-wired to have the mirrors be fully functional (heated and turn signals). A quick way to see if you're pre-wired is to remove that little triangle piece on the inside of your door where there mirror is.
There should be a wiring harness behind this triangle provided you have power mirrors. If that harness has 3 wires going to it, then you aren't pre-wired for the 3.5 mirrors. If you have 7 wires, you're most likely* pre-wired.
There are a few cases where people with 7 wires couldn't get the mirrors to work so thats why I say most likely...good luck and keep us posted!
toxik
Car: 09 Pearl White 370z
i thought coupe mirrors dont fit sedans and visa versa
Coupeguy23
Car: 2006 G35 coupe sport
toxik wrote:i thought coupe mirrors dont fit sedans and visa versa
+1 i though the coupe was different from the sedans.
boystar22
Car: 2008 Nissan Altima Coupe 2.5S
The coupe and sedan mirrors are not the same at all. The mounting holes don't line up, and the black triangle piece that mounts to the door is a completely different shape. The sedans' have a 3-sided triangle piece with a sharp point on top because the windshield has a steeper slope to it, the coupe mirrors have a 4-sided piece. Go on ebay and look if you need a visual reference, but trust me they are different.
But 3.5 sedan mirrors will bolt up fine on a 2.5 sedan; same goes for the coupe mirrors, they just aren't interchangeable between the body styles.
Rob.Vegan
I thought Rkitkt was just asking about changing a 3.5 coupe to a 2.5 coupe or 3.5 sedan to 2.5 sedan. I didn't realize he had a coupe and was asking about a sedan.
Franchise1124
Rob.Vegan wrote:I thought Rkitkt was just asking about changing a 3.5 coupe to a 2.5 coupe or 3.5 sedan to 2.5 sedan. I didn't realize he had a coupe and was asking about a sedan.
Ditto. Sorry if I confused anyone here. Reading > Me apparently
KilLer_KenZz
Car: '09 A/C 2.5S
wait...so can the 2.5 coupe have the 3.5's turning signal mirrors?
boystar22
Yea... I have them on my car.
KilLer_KenZz
Car: '09 A/C 2.5S
Nicee...where'd you acquire them? and how is the wiring for them..like, overly complicated or it can be done within an hour or two? lol
boystar22
KilLer_KenZz wrote:Nicee...where'd you acquire them? and how is the wiring for them..like, overly complicated or it can be done within an hour or two? lol
I purchased mine from nissanpartsonline.net They aren't difficult to install, just remove the the black plastic piece on the inside of the door, disconnect the harness, remove the three nuts and then swap the mirrors and do the reverse. Of course thats if you are pre-wired. If not you have to run the wires for the turn signals and the defroster. So depending on your wiring knowledge difficulty can vary.
To check for being pre-wired just remove the black piece and look at the harness going to the mirror. If it has 3 wires in it you are not prewired, if it has 7 wires you are.
Mirrors are $150 each, the painted "caps" are $14 each, and I paid $50 each to have them painted Deep Slate.
allensaltima
Car: 2009 Nissan Altima Coupe 2.5 S
i t
i tried this site as well as nissandiscountparts.com from killer lenzz and i couldnt find them on either...what am i doing wrong? what category would they be under? i tried to search for them but that didnt work either
boystar22
For the Coupe Assemblies http://www.trademotion.com/par...gid=0
For the Coupe Mirror Covers (painted pieces) http://www.trademotion.com/par...gid=0
On the drill-down menu its listed under "Door" > "Outside Mirrors"
allensaltima
thanks now i [QUOTE=boystar22]For the Coupe Assemblies http://www.trademotion.com/par...gid=0
thanks now i can see it..one more question tho..so you had to pay $50 to paint them? so your saying they come unpainted and then i have to go to a shop to have them match the color?
boystar22
Correct, the part that is painted on your mirrors now comes as unpainted black plastic. I was lucky and found the body shop my dealer uses, and they painted the two covers for me for only $50 each. Since they do all the body work for Nissan & Infinity they keep current paint colors mixed and ready so they are able to do it cheaper than a shop that would have to mix the paint just for you.
