2_Liter_Turbo »
https://forums.nicoclub.com/2-liter-turbo-u12924.html
Sun Aug 14, 2005 5:16 am
They will work just fine. You need the conversion lines, 300ZX rotors (26mm), retaining clips and all the rest of the hardware (assuming you just have bare calipers), and a set of good pads. That's all you need. You will have to modify or remove your dust shields, because the rotors are bigger than your old stock ones. If you have a base model S14 (4-lug), you will have to redrill the rotors to 5-lug and find wheels to clear the brakes. If you have an SE then the stock wheels will clear.
