will 225/40/17 on 17x7 rims?
s14noob
Car: 97 240sx LE 5-speed
hi. i searched on the web and most sites say that 225/40/17 won't fit on 17x7 rims and i would need at least 17x7.5. i asked local tire shops and they said that they would fit fine. has anyone on here used this combination? thanks
nismofly
Car: 89 Nissan 240SX Hatch
im assuming you have a 240, 225/40 is too small, run a 225/45/17, and it should be ok
whiterps13
Car: white LE hatch
It -might- fit, but a 225/45 would be much better.
s14noob
my bad. it's 225/45/17. i just don't want to be stuck buying the drag dr-8's and not having the tires fit on them...
nismofly
if theyre 17x7, whats the offset on them? ...they might not clear
crzycav86
Car: 93 Nissan 240SX KAT
The tires will fit that rim fine, but I wouldn't go any wider than that.
I'm assuming it has a fwd offset(+40>). If so, coilovers shouldn't be in your immediate future unless you want to invest in spacers.
whiterps13
Car: white LE hatch
The tire will fit on the rim. I had that tire on the back of my s13 with 17x7 +42's with coilovers, and it cleared. However, it wont clear coilovers in the front. A 205/40 WILL clear up front with that given wheel.
nismofly
205/40 is *way* too short though, you need a 205/50/17 for this car
plus 205/40 looks like rubber bands
BlackFlag_s13
215/40's end of story...
*Edit* I meant 215/45's but both will be fine..
sleepyRPS13
Car: to sleep
i have 205/40...before i had 215/45 on 7s and they lookd almost the same.
nismofly
theres an inch difference between the two, thats a 1/2 inch of sidewall
s14noob
the offset on the rims is +40. my car is stock when we talk about suspension. i'm pretty much stuck with using 225/45/17 because i bought a brand new set of 4 kuhmo 712 ecsta supra for considerably cheap compared to local shops. now for the clearance part, i'm not too sure as to how it will fit. however, you guys did confirm that 225/45/17 will fit on a 7" rim. thanks a bunch guys
nismofly
yeah that should clear with stock suspension
BIGT94z
nismofly wrote:yeah that should clear with stock suspension
so 225/45/17 will fit up front on a stock suspension with 17x7's....is that correct?
whiterps13
Car: white LE hatch
BIG_T wrote:so 225/45/17 will fit up front on a stock suspension with 17x7's....is that correct?
Depending on the offsets. Anything over +40ish is going to be REALLY close.
s14noob
whiterps13 wrote:Depending on the offsets. Anything over +40ish is going to be REALLY close.
i mounted them on a 17x7 + 42 offset rims. they clear with very little room to spare. it rubs in the front when i do super hard braking. other then that it's fine even when i fully turn the wheel.. i'll probably invest in some spacers when i lower the car. thanks for the help everyone.
Juujai
yeah those wheels are made for typically the front wheel drive crowd. 240s take really low offset wheels and what sucks is they shove us with 4 lug... can easily throw a 2 inch spacer on there no problem... but it might be unsafe not sure lol.
225/45 will be good you shouldn't stretch as theres a lot of sunken gap you need to fix.
