Will 2013 rogue wheels fit on a 2014?
Bass4ever
Car: 2014 Nissan Rogue SV
Looking for winter tires and rims for my 2014 rogue. Found plenty for sale used from 08-13 rogues. Will they fit on mine?
Stock wheels on mine are 17, found a lot of 16". Is the offset? Bore size, etc the same?
Thanks
Andrew
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
http://www.tirerack.com/content/tirerac ... epage.html
Nissan Rogue FWD SV
First gen. Size: 17x7.5 (O.E. Diameter) Offset: 38mm
Second gen. Size: 17x7.5 (O.E. Diameter) Offset: 38mm
Bass4ever
That works! Thanks!
I heard that when I change my summer to winter wheels/tires that I would have to go to the dealer to reprogram the TPMS? Is that true? Owned a bmw 3 series before and I could reset them myself... the rogue can't???
Rogue One
2022 Honda Pilot SE
If it's not too much to ask, if you're not going to use the SEARCH feature, could you at least click on the links on the ROGUE FORUM HOMEPAGE?
ROGUE CHATROOM: TIRES
Found using the SEARCH feature:
Winter Tires -TPMS & Wheel Questions (2nd Gen)
Thread closed.
Return to “Rogue Forum”
