yes...yes it is and has been for a very loooong time. Nissan cheaped out on usDAAN. wrote:
Why is the 2010 headlight so desired - is the projection the reason?
nissan messed up big time with their color profiles when they release their images of the new 2010 altima coupe. biggest fail ever.alphapig wrote:The 2008 headlight looks way better.
What you don't see in the pictures above is the Sentra bulge.
Is the guys you're referring about Brandon?..DAAN. wrote:I had projectors made by ontario guy, but weren't better than stock and took them out
I totally agree when you're comparing stock to stock of the two different front ends. However only a little modification is needed to the 08/09 and it looks like a completely different front end, at least IMO.Goon wrote:On headlights, I like the shape the new headlights: the bulge, boxy look with the quick curve, the less yellow light, and of course the projectors. For the body work, the 2010 hood has a better shaped, rather then converging on the 2008, and the grill on the 2010 felt more consistent to the design.
The front looks more together to the curvy back of the vehicle.
A 2010 coupe parked by me when I went to the DMV to update my registration renewal. It just had such a presence when I was approaching at its front.
I will have to look at the part numbers and do an estimate. It is definitely on a to do list by the Fall.
Thanks for the responses!
Ranga14 wrote: I totally agree when you're comparing stock to stock of the two different front ends. However only a little modification is needed to the 08/09 and it looks like a completely different front end, at least IMO.
