Will 20's rub at all on a 2006 M45?
Kadrian21
Car: Black 2006 Infiniti M45
I want to know will 20's rub if you put them on a 2006 m45 I currently have the chrome 18's from factory 245/45/18 will it ride any different because with factory rims/tires they ride really good will upgrading to 20's affect this cars ride quality I went to a rim shop and they stated they use 245/35/20 are these to thin any help is appreciated thanks for reading my post
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
Welcome to the forum, there are plenty of threads discussing putting 20's on the M35/M45.
The short answer is yes, 20's will fit, depending on the offset you go with.
Check out this thread: official-wheel-rim-thread-t509538.html
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Also, short answer YES they'll fit without a problem. You ate not identifying of you will be lowering your car any? Also is considering staggered or squared set up? In any case they'll both fit with the right width and offset, usually in the mid +30's +40MM. If considering a square set up of say, 20x9 offset+38 go with more rubber 255/35/20 more protection for your wheel and more cushion for the road! This will fit a stock height car AND a slightly lowered car maybe on springs... :bigthumb:
Kadrian21
No I will not be lowering it I want to go even all around no staggerd wheels straight up 20's with no modifications, is 255 the best tired I can go with without any problems
The Bodyguard
On a squared set up (all four the same) you are better off with 255/35/20 but still depends on the width of the wheels. 255 is good for 8.5" and 9"
