Will 19X9.5 wheels fit on the front?
UTgiant
Just like the title says, I'm thinking of putting 19X9.5 wheels all around on my 2002 Q45. Offset on the wheels will be +43. I know the rears will fit but just wanted to make sure the fronts wont have fitment issues. Anyone knowledgable about this please let me know. Again 19X9.5 with +43 offset. Will these have problems on the front?
Should be fine. 20's are not uncommon on that car.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
9.5s in the front with that high of offset is asking a lot. I have no idea if theyd fit but id probably wager more on them not fitting properly.
Rex
Car: None
elwesso wrote:9.5s in the front with that high of offset is asking a lot. I have no idea if theyd fit but id probably wager more on them not fitting properly.
I have to agree with Wes on this one. It's going to be "less than bolt on" to see a 9.5" wide wheel on the front of virtually any car. Expect to run a (somewhat) stretched tire and possibly have to run camber/rolled fenders. Even then it may still rub on the inside with a +43 offset.
one ton garage
Wow you will want to run at least a +20mm spacer all around. Or better yet, get a wheel with a better fitment to begin with and forego the spacers
widebodyq
Car: F50 Q45
Are you dropped? If not then you should be fine with a 255 or 245 tire
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
What's the deal with the cambered rear wheels? Looks kinda ugly to me. Like slightly retarded.
elwesso
2007 BMW M Coupe
Haitian_King wrote:What's the deal with the cambered rear wheels? Looks kinda ugly to me. Like slightly retarded.
I think you pretty mcuh answered your own question.
Haitian_King
But why do people do it? That has to be the most detrimental action to a Q's cosmetic appearance.
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
I suppose beauty is in the eye of the beholder. Some people think it looks BETTER that way.
Who knows... personally, I'm a standard fitment kind of guy.
Haitian_King
ceningolmo wrote:I suppose beauty is in the eye of the beholder. Some people think it looks BETTER that way.
Ew. I think it's quite ugly. It makes it look like the wheel is bent and the suspension is farked,
