Will 1999-2001 Xenon Headlights fit the 1997-1999 model?
thisdj78
If this has been asked before, my apologies. Will the headlights from a 99-01 Q45 fit on a 97-98 model? Obviously the connectors would be different, but I'm more concern with the fit.
Thanks!
EDIT: meant to say 97-98 model in the title
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, but you will not have in cabin adjustability.
Don't forget the ballasts.
thisdj78
maxnix wrote:Yes, but you will not have in cabin adjustability.
Thanks!
I have ballasts and D2 bulbs, so no problem there.
I imagine this also impacts the high/low beam functionality......has anyone (after doing the swap) encountered the xenons cutting off when high beams are activated?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
thisdj78 wrote:......has anyone (after doing the swap) encountered the xenons cutting off when high beams are activated?
Only all 1999-2001 FGY33 owners. Foglights don't work either when high beams engadged.
It is a D2R bulb, not a D2S.
timderiksen
Car: 1998 Q45t-wanna be cima
I have it done on my 98 and yes my fog lights do work when i hit the high beams
thisdj78
timderiksen wrote:I have it done on my 98 and yes my fog lights do work when i hit the high beams
Do your low beam-xenons stay on as well while your high beams are engaged? How did you fix the foglight issue? Did you add a special relay?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Did they before? On all G50 and FGY33 I have seen, fog ights are turned off when high beams are employed.
Modified by maxnix at 3:56 PM 4/21/2009
timderiksen
nah no special relay. i guess it how i wired up the headlight. Sometimes the turn off but then again sometimes the dont. i do know, just to wire up the headlight them selfs i used 3 relay 2 for power for high and low beam and one for when you turn on the highs the lows stay on.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
timderiksen wrote:nah no special relay. i guess it how i wired up the headlight. Sometimes the turn off but then again sometimes the dont. i do know, just to wire up the headlight them selfs i used 3 relay 2 for power for high and low beam and one for when you turn on the highs the lows stay on.
Once again your post is unintelligible but I'm going to cut you some slack cause I had me some beer.
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
I too find that a quart of the malt aids in ones comprehension and overall conviviality. I commend you on it's consumption. I would hoist a cup of brew in your general direction but I am too far into the Knob Creek at this juncture. To quaff a cold one now would blaspheme the blend.
timderiksen
well you im know not the brightest one when it comes to english
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Well anything directly wired to the battery can be on 24/7 until the battery dies.
