Will 1991 s13 a/c work with a 1995-98 s14 that has a KA24DE?
mrzabala
Car: 93 Nissan 240SX SE Hatch
I only have the FSM for the 91-94 s13 models. I was wondering if the stock a/c (I have the full a/c assembly) from my s13 (1991) will bolt right up and fit with no problems into a s14 (1995 and above)? Thank you for the help.
dkdeleon68
Car: 1991 240
yes
nismosteve
Actually it may not. I tried to put my s14 compressor on in place of my s13 and the pulleys didnt line up right. It bolted on the same but the pully was too far back.
ISUJinX
If you use the entire kit from the S13, it should fit. Mixing and matching compressors may give you the above result. .... but both engines are KA24DEs, so yes, it should work.
mrzabala
Yeah I have the whole assembly. Some guy wants to buy it from me for his s14 but wanted to make sure it will work. Now I got peoples thoughts about it so hopefully he will buy it. Its taking up room in my house and having parts in a big box just makes it heavier.
dkdeleon68
Car: 1991 240
nismosteve wrote:Actually it may not. I tried to put my s14 compressor on in place of my s13 and the pulleys didnt line up right. It bolted on the same but the pully was too far back.
thats because you have to switch power steering pump mount also so they line up.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
the AC unit on the S13 is quite different from an S14 the wirings different the compressors different the condensers different the lines are different the evaporate boxes is also different
