Will 18 Inch Rims Bend or Break?????????
johna_99_99
Car: 1992 nissan 240sx
hey guys im lookin to buy some 18 inch advanti rims for my s13.....the only issue is that i live northern ontario canada and the roads are not that great....bumps/potholes in a few places.....now should i get these rims....how hard do u have to hit a bump to bend or break the rim...thats the last thing i want to happen...thanks
nismofly
Car: 89 Nissan 240SX Hatch
not recommended, youd be better with a 17, best with a 16
johna_99_99
thanks man
whiterps13
Car: white LE hatch
first off, this question should be in the wheels/suspension forum you can find on your right. most people on this forum are highly against 18's on an s13, but personally i think they would look great. if you can find some that fit well (ie. width, offset, bolt pattern), and you dont care about rotating mass, id go with them. the only drawback is since you are running such a big rim, you will need a pretty low profile tire. this creates a problem with rough roads and such, but 18's arent going to crack, bend, or break any easier than a 16" or 17" with the same profile tire. just dodge potholes the best you can...
johna_99_99
sorry i forgot about the wheel/suspension forum.........thanks for the replys....ya i guess ill just try and avoid the pot holes....the rims are pretty sweet and come with rubber.....if you wanna take a look here they are:
http://www.son240sx.ca/forum/viewtopic.php?t=14833
sensibleS13driver
ouch definitely not worth 1200
naed240sx
Car: .....
johna_99_99 wrote:hey guys im lookin to buy some 18 inch advanti rims for my s13.....the only issue is that i live northern ontario canada and the roads are not that great....bumps/potholes in a few places.....now should i get these rims....how hard do u have to hit a bump to bend or break the rim...thats the last thing i want to happen...thanks
Yeah 18" is too big if you are concerned with performance. In order to maintain the same overall wheel diameter, really low profile tires are neccesary, which do not soak up as much of the force from hittting bumps as tires with taller sidwalls. I can't say that if you hit x pothole with y depth and z length then you will definately bend the rim. The best I can say is that they will bend if you hit a big enough bump/hole. It is impossible to say how large. Big rims will slow your car down because of rotating mass. People don't usually plus size rims more than 2". 16" is usually the best for the s13.
whiterps13 wrote:18's arent going to crack, bend, or break any easier than a 16" or 17" with the same profile tire. just dodge potholes the best you can...
Um yeah, but nobody is gonna put a 225/35 on a 16" rim. As long as overall tire diameter stays the same, with larger rims, there is less sidewall, making it easier to damage the rims. Smaller rims require a larger sidewall to maintain a certain diameter.
johna_99_99
thanks guys....i think im gonna wait and get 16s or 17s.......i think your rihgt about the 18s being too big......thanks for the input........take care
whiterps13
Car: white LE hatch
naed240sx wrote:Um yeah, but nobody is gonna put a 225/35 on a 16" rim. As long as overall tire diameter stays the same, with larger rims, there is less sidewall, making it easier to damage the rims. Smaller rims require a larger sidewall to maintain a certain diameter.
yea i know, but figuratively im saying that an 18 inch wheels isnt any more suseptable to breaking than a 16 or 17. the real variable here is the sidewall size, not the rim size. you get what im saying?
naed240sx
Car: .....
yeah definately.
blake@tirerack
If you are at all worried about pot hole dammage stay away from 18 inch wheels. You will regret it.
chmercer
if you dont get crackerjack knockoff wheels like the ones in that link, you wont have any problem bending wheels. some like 18s, some think its too big. regardless, thoes wheels in that link, suck ***, and cost way too much.
whiterps13
Car: white LE hatch
ahh some volk gt-7 knockoffs. i wonder what the offset is on those.
chmercer
whiterps13 wrote:ahh some volk gt-7 knockoffs. i wonder what the offset is on those.
bad.
