skydragoness5 wrote:If he was talking about rubbing his fenders with that offset, he would'nt have mentioned the agx's and the z-brakes. Because all can play a part in fitment issues--not just the fender. And i've found Exar-Kun, NismoFreak, and Smith SR are reliable sources of info since they all work at tire shops/tuning shops. Ask them for help if you need it.
Using the wheel offset calculator may help. What kind of rims are they anyway? I can never find 16" rims in good offsets..
Well +17 on an 8 inch wheel isn't a setup that I would be worried about rubbing coilovers, much less a shock and spring setup. However, the fender may be an issue. And I just wanted to point that out.
And I'm not doubting anyone's reliability, but there are some things in which it's more accurate to find out for yourself.
And if you want a good 16" rim, do a search for kosei k-1 every few days on ebay. Once in a while they'll have a 16" 4x114.3 bolt pattern up for grabs.
