HeavyDuty »
https://forums.nicoclub.com/heavyduty-u10182.html
Sun Mar 09, 2003 8:06 pm
Hey elwesso, sorry for the bad info guys. I bought my 91 SE-R FSM (factory, field, whatever) from Helm, but that's been yeeears ago.
1qckser, we have an inhouse (outhouse :pface ) transmission shop. We have curently been working on Acura TL-S/CL-S upgrades with better clutches (better material & more of them per set) & valve body work, hardened shafts, multiple choice stalls, depending on app, (high cr or stroked 3.5 or low cr stroked with forged pistons, Comptech s/c, NOS, etc.)
We use the same parts & can perform (per request) modifications along the same lines as a well known shop in NJ. My builder has been hands on for 30 years. I didn't come here to sell trannies, but rather learn about my car. If someone needs assistance though, I'd be happy to assist them.
On mine, we didn't want to increase the line pressure too much (firmer shifts) becuase I'm waiting for my JWT ECU & TCU, which I believe will firm the shifts as well as 1st gear start, etc. If it's not firm enough after the TCU, we'll go back in & firm it up more.
The stall isn't bad at all, maybe 300rpm higher, but will be slightly higher with an increase in torque expected from the ECU upgrade. In Drive with my foot off the brake, it doesn't roll away like it used to, it takes (very) little throttle to smoothly drive away. Right now with stock ecu/tcu, it holds the gear a little too long, with more power up top it should pull nicely up top & not have the lag at the high end it does now.
