WiFi vs Data question
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
So, I just got a Samsung Captivate and was required to sign up for a data plan w/ AT&T. The phone also has a WiFi feature, letting me connect to my network at home, school, etc. Now, I know this doesn't count against the data plan I signed up for, but is there a limit, datawise (MB, GB, etc) as to how much I can do when connected to WiFi?
Otto.
Nope. Use as much as you want with wi-fi.
If there is wi-fi wherever you happen to be using your phone, you should turn 3G off. It will conserve battery. :)
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You are correct.. I have an iPhone and when I am connected to WiFi it doesnt use data... There is no limit to what you can use via wifi
You will have a hard time using 2GB unless you're downloading pr0nz non-stop.
ProudNissanFreak
Sweet! I have 3G off. My data plan is 200MB (I mainly use it for e-mails with my clients and such), but I do like to surf the web on occasion and not worry about going over that limit. Yay for unlimited!
Thanks guys :D
ProudNissanFreak
Also, will using apps like Pandora affect my data limit when on Wifi?
Otto.
ProudNissanFreak wrote:Also, will using apps like Pandora affect my data limit when on Wifi?
Nope.
ProudNissanFreak
Ok, so just a final clarification, because AT&T has pulled s*** on me before: I can do whatever I want, download and run apps that go online, etc when I'm on WiFI w/ no affect on my data plan? If so, that's awesomesauce.
Otto.
ProudNissanFreak wrote:Ok, so just a final clarification, because AT&T has pulled s*** on me before: I can do whatever I want, download and run apps that go online, etc when I'm on WiFI w/ no affect on my data plan? If so, that's awesomesauce.
Yep. Just make sure you have 3G off when doing anything over wi-fi... maybe just keep it off all the time unless checking your email.
ProudNissanFreak
Awesome. 3G is off and I'm good to go. Thanks a bunch Otto and Wes! I'm new to this smartphone thing, haha. :-P
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
http://www.appbrain.com/app/3g-watchdog ... g3watchdog
Very useful for people on limited data plans. Download a 3G toggle widget and you're set...turn it on when you need it, turn it off when you don't...without diving through the Settings menu.
MaximA32
I used 661MB or 0.65GB of data last month. That was streaming full episodes of Lie to Me via my Netflix app and several total hours of Pandora streaming. Luckily I got grandfathered in on the unlimited data plan.
float_6969
I'm grandfathered in on unlimited data w/ATT as well and I've never exceeded 1GB. Came close ONCE. (900+MB). Most of the time I'm in the 3-500MB range. And I'm CONSTANTLY on the web.
float_6969
