karmapolice991 wrote: A couple weeks ago while geting turning on an off ramp i noticed my front left wheel was makeing these scrapeing noise. Ive also notice that it only makes a noise if i am takeing a left hand turn. Other than the sound there is no diferance in driveing or ne vibraton to the stearing wheal. What could this be I wasnt to fix it before It causes me any more problems.
Check you power steering fluid. I had the same problem when I first got my 240 and the power steering fluid reservoir was bone dry. Just remember if it needs filling to use ATF(automatic transmission fluid).
And to the second poster, might be a wheel bearing. See if you can move the wheel in and out by hand if its off the ground. If its constant I'd consider getting it checked out.
