Wierd Vibration
SimpleEnigma
Car: 1992 240sx Coupe
I have a '92 240sx SE coupe and just got the Clutch replaced at 82k miles recently. Now i am noticing a wierd vibration at ~20mph, but only when the car is in gear. Feels like it is in the drivetrain somewheres....any ideas on what it may be??
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
I'm not sure what it could be if you're only noticing the vibration when your car is in gear... I had/have a vibration going through my car and for my situation the vibration is there whether I am in gear or not, but it is coming from the carrier bearing that holds the driveshaft in the middle. I replaced the bearing but one of the bolts that holds the carrier bearing housing is stripped and therefor allows for some play so the vibration hasn't been fixed as of yet... As soon as I get some time home from school I will probably get it fixed for good. Hope you find this helpful!
