wierd transmission problem(help)
project240racing
Car: racing
Ok this is really messed up i need help.........i have a 1991 240sx automatic....the car has an original 48k miles...The other day i got in the car started it and tryed to put in in reverse and it wouldent leave park(the only way to get it out is to push the shift lock button and slide the shifter......than u can change to RND12.)this seems really wierd to me for this mileage has anyone had this problem or any suggestions:eek:
240nismo
Car: Master of bation
get a 5-speed ;)
project240racing
Car: racing
dont have the money
Boricua
my car is a 1990 automatic transmission i dont know if is the same type, but try to check the two switchs in the back of brake pedal, (i have two) (stop ligth & cruise control), and/or remove the (RND12) cover and you see a "mechanic switch" check the cables connections and the signal (you will need a ohm/volt meter).
i think that your trany is good maybe is the switch...
well maybe this help :)
and i hate when people said "GET A MANUAL transmission" some of us love automatic... :)
p.s. sorry for my english..... :p
240_2NRman
Car: soccer, snowboarding, skydiving, LOVE CARS
most cars have 3 switches on the back of the brake pedal...brake lights, cc, and park safety switch....that switch detects whether or not you push in the brake to allow you to shift into gear
project240racing
Car: racing
thanks for the technical advice ill try that this weekend
