cowboyrps13 »
https://forums.nicoclub.com/cowboyrps13-u567.html
Fri Jul 16, 2004 6:38 pm
just yesterday a wierd tapping noise started to emit from under my hood. i only heard it on start up, three loud taps, then it went away. well today i noticed that when the engine hits 3000 rpm and the throttle is at a certain position, it continues to tap. now if i floor it? nothing, coast? nothing, accelerate? only are about 1/4 throttle does it make the noise. if you keep a steady acceleration then the noise continues up into the rpm range. when i popped the hood to listen to it myself, i had a friend make the rpms jump between 2500 and 3000. it sounded like it was coming from under the valve cover. i just had the valve cover off to get it powder coated, could i have possibly knocked something loose? maybe put it on wrong or got something inside? i also replaced the gasket and the bolts, is it possible i need to retighten the bolts? im gonna try that in the morning. any help is appreciated!
Thanks!:help
