wierd tapping no horsepower HELP!!!!!
1989nismo
Car: 1989 240sx 1973-240z
had a new clutch put in now i have no h/power and this loud taping noisecoming from motor not a rod knock but sounds like something is slaping around in there Oh the oil light is on but has plenty of oil. Help me out guy's really bumed. also has bd exhaust leak would this cause maybe the MAF to go crazy, ECU maybe I have know clue?????
Modified by 1989nismo at 10:30 PM 6/11/2009
Bongpain
Car: 92 240sx
who did the clutch? and did it happen before or after you did the clutch. there maybe a good chance that the clutch not bolted correctly. resulting in lost of power and knocking noise. i believe if the clutch knock hard enough it may throw off the knock sensor and the ecu may compensate for something that is not there. i would look at the clutch job first. oil light will come on if whoever did the clutch forget to plug it back in. because is located near the starter and bell-housing so it may be removed to make room to get to the bolt. also look at the bolts on your drive-shaft make sure that is tight.
480sx
Car: 1996 Pearl White 240sx
Bongpain wrote:who did the clutch? and did it happen before or after you did the clutch.
You should have stopped there you high bastard. The rest of your post is complete crap.
First of all, your oil light is on. That is priority number one. Stop running the car, and figure out what is causing this. The oil light sensor is on the oil filter plate (distribution block). Its mounted on the same thing your oil filter is mounted on. If they were just doing a simple clutch job, they shouldnt have messed with that.
Is your oil light one steady red all the time or does it sometimes go away?
posh jop 240
Car: '91 240sx hatchback
deffinatly figure out the oil issure first.. because if you dont have oil pressure you can say bye bye to your motor. then get back to us and see whats up. the clutch deffinatly shouldnt cause any engine noise...
Bongpain
Car: 92 240sx
fuc you stupid a** if you have no advise don't post you fagits never a simple clutch job. you stupid f*** and if you have done one maybe you know sometime its easier for some one to pull or accidentally pull it out. STUPID f***S LIKE YOU GIVE THIS BOARD BAD REP. you obviously didn't give any ideas so why the f*** are you posting on his question. i didn't ask you for your f***ing advice stupid f***.
480sx
Are you sure your not confusing a crack pipe with a bong? Jesus get this guy off my forums..
I know you didnt ask for my advice. The OP asked for advice, and i gave it to him. The only advice i coujld ever give you is to STFU and go take an english class.
Wow i almost want to get into each and every line of failure but ffs, just GTFO.
