Luke wrote:Please SEARCH, this has been covered many times.
Do you have an aftermarket Blow off valve that is not recirculated? If you do, you're blowing off air that is metered by the MAFS, causing the ECU to give the engine more fuel than the air flowing into the engine.
This means when you let it drop down to idle after accelerating, the engine gets too much fuel and dies. Your possible solutions to the problem (easiest to hardest):
- Get some type of Fuel management (S-AFC, etc.) or ECU that will compensate for this common problem. - Connect a hose from the BOV to your intake pipe AFTER the MAFS. (recirculate)- Do the "Blow-thru" setup and place the MAFS somewhere in the intercooler piping AFTER the BOV. More custom work is required and it cannot be done with the stock SR MAFS (Z32 mafs is needed). This is not recommended because of the difficulty and possibility of oil contamination from blow by oil in the intake.
Many people, including myself, do not recirculate and do not use a blow-thru setup. I get a slight backfire every few times the bov opens. It's not a big deal and the rpms do not drop.
There is clearly another problem. It could be the injectors. Or if your intercooler piping popped off that would happen. It sounds like air isn't rushing past the maf. It could be bad, and you can test it by following the directions in the fsm.
