danielsan »
https://forums.nicoclub.com/danielsan-u94265.html
Wed Jul 16, 2008 7:58 pm
it sounds almost like pinging but has a squeaking sound to it, almost sounds like an exhaust leak, hence why it think its the plug. also the plug has deposits on it that none of the others have. the deposits are metal erea between the threads and the cermic. im running ngk oem. its not pinging though because its still there when i retard timing all the way and im running 91 octane.
under the valve cover everything looks good. cam lobes are clean and smooth, no foreign objects in there.
no strange idle, no loss of power, runs like normal. sounds does not increas with rpm. its a steady sound. though my exhaust smells like fire crackers though.
here is a pic of the suspect plug (#4cylinder) to #3 cylinder plug, by the way the rest of the plugs look like #3. #4 is on the right.
