Wierd serious problem, need help ASAP!
Assmunke
strange thing is happening to my car. i just installed a set of spl tension rods, and besides having to cut off the rusted bolts holding the bushing to the control arm it went fine. My big problem is that when i went to test drive it, i found that whenever i took a 90 degree turn, or swerved the car a little, the car would lose all power for a split second, (like someone was shutting off the car and turning it back on over and over) and continue doing it until i crammed on the brake- which would fix it. now my antilock warning light is on and i am scared to turn too sharply. could it be an engine ground i knocked loose while cutting and pounding? why are my antilocks screwed? i have no idea what the prob is and i would realy appreciate any pointers in the right direction. thanks.
MikeMurphy
Car: Guess
bump for a quick response from some of you guys if you see this!
Help a fellow 240 out =) He is not going to have any money left for go-fast toys!
i2ice4m3
Car: COUNTERSTRIKE!
hah i'd like to help but i really have no idea what you could have done removing and installing t/c rods :P
yellow_jacket
Car: 95 240sx
Check the abs sensors. make sure you didn't unplug one, eat through the wiring, or have one come loose. That is the only thing I can think of that you might have done. If it is not that, start looking at all of your electrical connections. You might have a loose ground somewhere.
Assmunke
will do- thanks for the reply!
