lovemy89240 »
https://forums.nicoclub.com/lovemy89240-u149336.html
Sun Jan 15, 2012 7:25 pm
the only mods on the motor is a front mount, .50/.63 turbo and an emance tuned ecu for those upgrades. and its ran fine for months with those upgrades
It has a weird idle, fluctuates, sounds like its struggling to stay running and a slight misfire , but never died.
When driving it feels like something is holding it back, around the 2000rpm mark the car would hesitate and spit and sputter and not want to rev then itll rev to 5K but with reduced Power.
Ive replaced the O2 sensor with a Bosch piece, Ive also replaced the Coolant temp sensor, and the ECU isnt throwing any codes.... so any questions or possible fixes are welcome
here are some AFR's from my wideband
idle 13.0:1 - 17.0:1 usually around 14:1 - 15:1
first gear start= spikes up to 20.0:1
wide open throttle from 1200-4k rpm 10.5:1 - 11.0:1
while shifting spike to 16:1 - 17:1
maintaining speed (about 50) 14.0:1 - 15:1
deceleration in gear 9.0:1 - 12.0:1
and during a normal drive with a mix of hard and soft driving i saw a min AFR of 9.7:1 and a max of 21.4:1
