Wierd problem with my 240, please help!
VinceSez
Car: 1992 Nissan 240sx
I have this wierd problem with my 92 240sx. When I drive my car for 30min-1hr it begins to bog/stall as if it were choking. When i press on my accelerator from a stopped position it runs strong, and then it would bog/stall. It would run hard then bog/stall every time it tries to increase in speed. My car is completely stock, except for a hotshot header i recently installed. I just noticed this started to happen after I insstalled my headers.. what could be the problem??thanks for the help
SR20_RPS13
Check fuel pump
VinceSez
eee.. lol where exactly is the fuel pump? is it connected to the fuel filter? sorry for the newb question
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
its in the trunk ont he passenger side, located under a plate that is held down by four 10mm screws that have phillips heads inside of them.its underneath that plate
VinceSez
alright, ill check it out today... thanks
SR20_RPS13
You might have to bend the metal wire to get it out.
